I have had several boxes/phones before,and every now and then I have got the message "release memory....
Because there are not enough space to install more apps.
I got the message 2 days ago,and I have uninstalled several apps,but still getting the message.
In Storage-Apps,.I use 2.61GB....
My box is rooted,so im free to look in any folder if any app stores a lot of space..ex XBMC.
I have cleaned caches and rebooted several times.
Any folder I could "look in to" ,for realeasing space?or something like that.
Maybe this app can help you find what is taking up the most space. If that's the problem. Sorry if I'm misunderstanding the question. This is a must have app anyway and should be default on every android
yes,I know that app.
But as this thing is rater common among Android devices,I thought that some "Minix people" knew a solution.I have contact them.but from where I can tell they just blame it on everything else..*L*
Lot of hits on Google on this problem.And I have had it before on a phone,and friends have had it to.
I would rather call it a bug,on Android..whats good is that I dont have so many apps installed,so if I want to install a new app,then I think I will reset the box,and take an hour and fix it.
I got this on my nexus 4 a couple of weeks ago, I had to wipe and reflash rom and apps. Gl
Sent from my Nexus 5 using Tapatalk
Ok.
I have had it before.
And its no problem for me to reset the box.
But its strange that the developer´s of Android havent been abel to fix it.Since it is a rather big,and common problem.
It seems to be the solution.
Reset the box.
Thanks!
