ShaunMT's Modified ROM for Nextbook NX785QC8G (Download Thread)
    Description:
    This is a modified ROM based on the official KK 4.4.2 update for the Nextbook NX785QC8G.
    Modifications:
    • Root Enabled with Su and SuperSu.apk
    • Root ADB access Enabled
    • Both ADB and Mass_Storage Modes Enabled
    • Init.d Boot Scripting Support Enabled
    • Minimal Debloat (You've got root access... feel free to remove whatever else you like.)
    • Freaktab / ShaunMT Splashscreen
    Please make sure you download the correct ROM for your device!
    These files will be named in the format: SMT-"model"-"board"-"Android_Version"-"stock_build_date"-"optional_info".zip
    Verify
    model and board in your stock build.prop before downloading: ro.product.model and ro.product.board
    You can also check boardin ro.build.product, ro.build.description or ro.build.fingerprint
    These ROMs are believed to work on all matching model and boards, unless noted otherwise. Install at your own risk...
    Installation:
    There are two formats available:
    RKIMAGE Format (A Modified Version of The Full Official KK 4.4.2 Update):
    Download:
    SMT-NX785QC8G-NXM865FD_WMDE-KK_4_4_2_052714-RKIMAGE.zip
    Unzip and remove update.img file...
    There are 3 possible ways to install:
    Option 1: Put the update.img on your external SD card, boot into stock recovery, choose update rkimage from external storage, wait...
    Option 2: Put the update.img on your external SD card, boot into android, choose yes when prompted to install update.img
    Option 3: Flash from PC using one of the many rkflash tools (you'll have to look elsewhere for flash tools and instructions... check the forums here at Freaktab)
    After install... I strongly advise doing a factory reset and recommend erasing internal SD card also.
    Also, don't leave the update.img on your external SD card, because you'll be constantly prompted to install it over and over again...
    UPDATE.ZIP Format (Same as the RKIMAGE Format, but flashable in TWRP and Only Includes the Modified Boot and System partitions.)
    Download:
    SMT-NX785QC8G-NXM865FD_WMDE-KK_4_4_2_052714-ZIP.zip
    NOTE: The update.zip version requires approximately 4GB of space on your external SD Card, Nearly 2GB for the udpate.zip file and nearly 2GB during installation to extract the files before flashing.
    Support Thread:
    ShaunMT
    Last edited by shaunmt; 03 December 2014, 09:55. Reason: Added TWRP Flashable Update.Zip
    Freaktab Rom Developer
