I'm really enjoyed to use a Minix NEO X7 with Finless 1.9 ROM, but I have only one problem: when I try to use ethernet connection, it connects and disconnects continuosly.
I've tried to turn on/off wifi, setting up dhcp/static IP with different IP numbers, but not working.
The X7 is connected with eth cable to a 10/100/1000 Cisco switch, maybe the "1000" speed mode is the problem??
Thanks in advance for your help.
