Has the X8 an auto power on jumper like the NEO X7?
    Does anybody know if the Neo X8 has an auto power on jumper like the NEO X7?
    Or is there any other way to start the X8 when the power is turned on?
    My media devices are all on remote controlled power sockets and it would be nice if the X8 would start automatically when I turn on the power for the TV and the sound system because then I could place the X8 behind the TV instead of beneath it like I have to do it now.
    Yes there is such a jumper. If I recall correctly, it's near the power button. There are some high resolution images of the board in the "Minix X8 not powering on" thread which should help. Our just open the box and have a look.
    I can't really link to anything right now since I'm just on my phone, but I can edit this post tomorrow if you need more information
      Originally posted by Arbelzapf View Post
      Yes (...) high resolution images of the board in the "Minix X8 not powering on"
      Thank you!
      I have found the thread and the picture
