Periodical audio stop
    Greetings,
    I'm having a neo x8-h with beta008 firmware and I'm the following problem:
    Every 10 minutes or so, the audio stops for about 10 secs, it doesn't matter what I'm doing, playing music or movie, or doing nothing, the sound stops every 10 mins. I've been searching for solution but seems no one encountered it so far. After some reboots, the situation gone off but yesterday it happened again
    I'm just wondering if I'm having a faulty box ? Should I return or change the box
    Maybe it is a problem with the beta at your device, so maybe try this:
    and this is the link to Finless 1.0
    (or using the hole Finless 1.0 instead of beta8)
    RK3288 Devices
    - Overview BOX (LINK !)
