MK802IV and passthrough
    Hi All, I have the new MK802iv and am trying to get it to play nicely with my HDMI 5.1 amp.
    When i use a raspberry PI with XBMC 13.1 my amp registers the correct 5.1 audio.
    When i use the 802iv with passthrough enabled in Android and in XBMC 13.1/13.2 my amp registers the sound as LPMC and it's out of sync by a varying random amount (one minute its slightly out then several seconds, then out the other way, really annoying!).
    I have tried the stock 4.2 and 4.4 firmware and have the same problem with both!
    Anyone know whats wrong or any custom firmware that plays nicely with XMBC AND AC3 5.1 sound?
    I installed a custom ROM and SPMC (13.3).
    My Amp see the DTS and DD 5.1 sound but there is no or bad sound.
    I'm also still looking for a working solution ...
