Problem with q7
There is an option in the deeper menus of your q7 which tells it to use date and time provided by your network.
If this is already activated and doesn't work properly you should check your router which ntp server it provides.
Or you try to install this apk:
and build up an time setting script which you put in the init.d folder - this app emulates init.d (something like autostart from windows) and starts scripts automatically right from start up from the init.d folder.
init.d (= initiate daemon i think.)Kind regards Snuffy
HotLinks: MK918 Stock Rom Collection // Q7 Stock Rom Collection
Fixing the always changing MAC address issue
I mentioned it - Android is linke Linux ... Google for an ntp script
This post was created with Tapatalk. Plesse excuse any spelling errors. I'll do my very best.Kind regards Snuffy
There are currently 2477 users online. 1 members and 2476 guests.
