Power supply issues
Originally posted by sutty86 View PostWhat's the right voltage for the box having issues atm and believe it's the power supply.
I use a 5vdc~3amp.
If you are using one of those Quality plug convertersyou may have more issues
Cheers
Originally posted by sutty86 View PostCool I have one at 12v2a and having issues
Blue light is on but no show on tv
Could be HDMI cable try another or output of box has gone to lala land and tv can't find it has happened to me.
Plug and pray I think is the quote often used for some of these boxes.
Cheers
(If you use the 12V than the box lights up for a very short moment)
5V with 3A is a good idea and the connector should have 5,5mm x 2,1mm ...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by sutty86 View PostMaybe my daughter's have mixed up with mx2 box supply is that 12v
I'm so confused
As mentioned they are normally 5vdc~2amp
If the blue light is still on you may be lucky BUT.......
Originally posted by sutty86 View Post**** my life I just figured what I've done wrong,basically got a new tv and stand moved it all around and basically got my cables mixed up and I have a card sharing box for satellite and I believe I've mixed up cables.cheers fellas hopefully will check now
Hope it works out well.....
Warranty maybe...but i didn't say that and no one saw me say it
Originally posted by sutty86 View PostHa warranty no chance just bought an Amazon fire tv,imported from the u.s,
These boxes get addictive,nearly bought the mojoRK3288 Devices
Originally posted by no_spam_for_me View Postfrom where or how do you import the fireTV ?
Cheers...
There are currently 5405 users online. 4 members and 5401 guests.
