Help i have a brick k-r 42
    I try to flash justxbmc latest version onto my devices,
    but now it wont boot and unable to boot it back into recoverory to reflash,
    my board is B351_v2.0 2013/09/22
    Please help thank you......
    On the base of the box there is a little switch that you push and hold in in whilst you then connect the USB cable from the OTG port into your PC.
    Hold the button in for 2 or 3 seconds and you should be in flash mode that will allow you to flash a stock or alternative custom ROM.
    Make sure that the box is not already on when you carry out the procedure.
