Boot Animation Software...suggestions.
    ...not exactly sure what is compatible. Looking for a wide variety, simple to complex. With audio if possible. Thanks!
    If you are talking about software to create them then there are a few that you can google.
    Boot Animation Creator and Boot Animation Factory are good and easy to use.
    You can also get freeware that can convert video clips and animated gifs to jpg/png sequances that you can use a as a base for an animation.
      ^ thanks!
        Appreciate the idea of moving the video clips to a gif file. I have found that Boot Animation Creator has ended support and just moved to Boot Animation Factory. Taking a look at it now. Any other suggestions are most welcomed!
