Need Meazy U4C to look like vizio costar or google tv box
Cant download app from play store needed to run menu on tv. had a costar that broke and replaced with meazy not thinking that google play would tell me menu app not compatible with device. no i need to change build.prop but dont have fingerprint to use. kind of a novice at android stuff. -
You could try to side load it. There is a page where you can download the apk's of most free apps from the play store, search for "evozi apk downloader" and once you get there if someone has requested it before, you can download it. After that, all you need to do is install it.
Now, this does not guarantee that it will work with your device, but it is worth a try...
I do this with my sticks because I don't have any paid apps on the play store, so I side load them all from a folder on my memory card.Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
There are currently 3347 users online. 0 members and 3347 guests.
