VNC can't really remote control my CS918 T-R42
    I set up my CS918 T-K42 (kitkat 4.4.2 stock rom) as a 24x7 bittorent by attaching an external 2.5" HDD. It works flawlessly. I also successfully rooted it.
    I wish to control my android box from my office via VNC viewer. I have tried a lot of vnc servers on CS918 and use VNC viewer on Windows or Ipad to control it. VNC viewer can connect and display my android display properly, with a mouse point (small cross); the problem is though I can move the mouse all over the display, but when tapping the screen to choose Home, back, etc functions, it did something else.
    Anyone knows how to solve the problem.
    Had you also tried
    VNC Server
    RK3288 Devices
    - Overview BOX (LINK !)
      Thanks. VNC Server also have the same problem.
      Got some tips from comment part in the Play Store.
      Some basic key map:
      (A)Home= (PC)Home+click
      (A)Back= Esc+click
      (A)Menu= PageUp+click.....
      The above key combination works for me.
      Apart from that, I still can't use on screen cursor to choose app to run, and to control inside the app.
      Assistance from you guys would be really appreciated.
        I don't use it at the moment and only test it with the server above for a short time so I'm not sure if I have the same problems (but can't remember), but as client I use tightVNC (http://www.tightvnc.com/)...
        RK3288 Devices
