is it possible to key map melee f10 pro?
    as above, I've got the melee f10 pro, although some of the buttons work most of them don't i.e i don't have a home button or menu button or power button, does those of you using this remote have the same issue or is there a way to mao the keys to get more use of the buttons, cheers
    RK3288 Devices
    - Overview BOX (LINK !)
      I've tried this method and no change, not sure if I'm doing it wrong, does any one have a link to the file i need and i can copy and paste it to the folder to see if that would work?
