so I managed to brick my beloved little Nextbook 8HD, and now I need help
getting the tab to run again. Yes, my fault, I admit I screwed up and have
to bear the consequences.
Here's what happened:
The tab is a Next8HD8G made in january 2014. It is rooted, USB-Debugging
is TURNED OFF. Trying to install a custom bootanimation.zip unfortunately
bricked the tab by leaving a black area in the size of the bootanimation
picture overlaid over the screen.
The tablet boots but all but the bottom 1" of the screen stays black. The
bottom 256 pixels (roughly 1.5") can be used, and the black area of the
screen does react to touches, but obviously I have to use it blind.
In the system/media root folder I got the bootanimation.zip which is corrupted,
and a backup named bootanimation.zipx of the original file.
Basically, what I need to do is to delete the /system/media/bootanimation.zip
file and possibly rename bootanimation.zipx back to bootanimation.zip. But
without being able to see what I'm doing, that is kinda impossible.
What would help me a lot would the following:
A way to access the root data from within windows. Obviously USB debugging
will have to be turned on for this. For that to happen I will need screenshots
of the Develloper Options menu that guide me step by step to enable USB
debugging, since I don't see what I'm doing and have to enable this blind.
Or maybe there's an easier way to get this fixed?
I really hope someone here can help me to get my little tab running again.
Especially since where I live it costs about twice the US price.
Thank you,
-Clyde
