New firmware: 140822
    There is a new Firmware availalble on the official forums:
    Tools here: http://www.rikomagic.co.uk/downloads...02II_Tools.zip
    Changelog is:
    1. Fixed Ethernet issue
    2. Support H.265
    3. Fixed 720p display issue
    Here are my test results:
    - Ethernet went from not working to slow (1Mb vs 50Mb with Wifi)
    - Antutu score went up : 27000 to 33000
    - Some H265 files that were not working are now working
    Problems still present:
    - Ethernet not working properly
    - 2160p@60Hz not present in the display settings (I have a 4K HDMI 2.0 TV)
    - Sound still mixed down to Stereo using (HDMI and SPDIF)
    - When i change my HDMI source on my TV then come back to the RKM, the display stays black, I have to reboot MULTIPLE times to get it working (but the boot works, I hear the mail sound)
    - Using 2160p@30Hz, android is still 1080p scaled up. The only 4K content I can see is the Video Player, I wrote an app that says running in 1080p.
    I just did the update
    Wifi is still faster than ethernet.
    Netflix is still not working.
    Seriusly hope some good developers buy it and fix it :-)
      Netflix not workig some 1080p issues mk902ii
      Yes .... Super snappy ! But I placed back my mk808 as netflix is my preferred app.
      Finless ROM!!!!!!!!!!!!!!!!! Please help US!!
      Trycage
        The MK902ii is compatible with ROMs and kernels from the following RK3288 devices:
        Cloudnetgo CR12/13/16, Bluetimes QPRO, Measy B4S & CS918ii
        ...latest [09/11/14] firmware can be found here:
          http://www.FreakTab.com/showthread.php?p=226780
          Anyone tested this?
          If so could anyone post a direct link.
          Looks like there are several roms in that thread.
          And if u have tested, do netflix work? :-)
          Thx, not home atm so cant really test anything, but if helps me get a box that actually works then that would be great :-)
            This is your latest firmware. There are others; I don't use Netflix, maybe someone else can test that functionality.
              https://mega.co.nz/#!acxVQASb!-8ZFJU...NblLgYdAl3yEc0
              How do I use this with andriodTool v2.3?
              Wanto make sure I dont mess up.
                I just tok the kernel.img and flashed that.
                Did a speedtest on internet and got 35/40 mbit... So thats improved a lot !!!
                Looks like netflix still wont play anything..
                Box is still useless for me unless netflix and hbo nordic dont work :-(
                Hope next fix takes care of this...
                Maybe flashing some of the other files will fix this...
                Really no clue what Im doing :-/
                From what I know I might have done nothing and ethernet just works now, lol
                  Tried new system img file..
                  Boot was different, but netflix still have issues playing...
                    Flashing just the kernel likely did nothing as most these RK3288 firmwares have an embedded kernel in the boot.img which overrides the kernel.img partition. Being that the original MK902ii ROM comes from the same software house, I'm sure it followed a similar convention.
                    Additionally, when testing something like firmware compatibility with Netflix, I highly recommend flashing all files including boot.img. The boot partition contains drm elements/objects which are necessary for playback of certain content.
                    This is the firmware I recommend you try:
                    It's from a different software house and is better than the 09/11/14 firmware in my opinion, anyway. It is later than the original firmware that shipped with the MK902ii.
                      I have just purchased a Bluetimes QPro and one option the factory agreed to preinstall was Netflix. So I assume that it works with the ROM they supply otherwise they would not offer to install it and test before shipping.
                      As mine shipped yesterday I assume the firmware was the same as the one posted by Shomari.
                        Try this Netflix version and please report back with your results:
                        If it works that means the factory is up to something funny.
                          I will try it when the box gets here
                            Re: New firmware: 140822
                            ...thanks, was more for ringdal that said his tv box is worthless without netflix
                              You mean the Ethernet went from very slow to 35/40mbit?
