Within minutes of receiving the box, I flashed Bob's Finless 1.9 ROM. When setting up the box, it would sometimes shut down suddenly (after a few minutes or after over an hour). Sometimes if I tried to turn it back on immediately, it wouldn't do anything (no blue or red light at all). It would turn on finally if I waited a bit longer, but sometimes it would die again before booting up to the main menu.
I tried different ROM's: Finless 1.9, Wasser 1.0.3, Oman's stock 108k4 and even Finless 1.8. I also tried 2 better quality 5V2A / 5V2.5A power supplies. None of that solves the problem.
BACKGROUND:
The box originally came with stock 103k4. I used Oman's XBMC 13.1. Most of the time, the box shut itself down when I was setting up XBMC (moving up/down in the menu, entering the repo name, tinkering with other settings, etc.). At first I thought it was the XBMC, but then I encountered the same problem even in the box media launcher setting menu.
I searched the forum extensively, but was unable to find a solution. Can someone please help me with that?
UPDATE:
I put Finless 1.9 back on and tried playing a rmvb file stored on the network. It shut down within 15 minutes for twice and I had no interaction using the remote control or air mouse. This is frustrating.
Thanks.
