M8 Android TV Box
    M8 Android TV Box
    I just purchased an M8 Android TV Box Quad Core. I loaded XBMC on it and the problem is it shuts off when I am in XBMC. I can't get any video when I go to movies only audio. Is there an update for this box that I need to install? Any help would be greatly appreciated. Thanks.
    check this link
      M8 android tv box
      Thanks it works.Now if I can get it to stop buffering
        Have a look here may help.
        Cheers
          M8 Android tv box
          Thanks I will give it a try
            which one did you use from the list?
              M8 Android tv box
              i had a friend updated for me I will check with him and let you know
