Working/Non-working apps
    Had some problems to fit these in the already started threads.
    Tested some screen recorder apps yesterday and a mirror app, these are the result:
    SCR Screen Recorder Free ★root
    Result: Couldn't start recording - error message
    Rec. (Screen Recorder)
    Result: Black screen. Had to manually restart the box
    FREE screen recorder NO ROOT
    Result: Started recording and creating video file but video file seams corrupt
    MirrorOp Sender
    Result: Worked
    Beelink R89
    Pioneer SC-2022
    Samsung 55" LED 2012
    Previous:
    Minix X8-H
    Minix X5
    Logitech Revue
    So what I get the info is MirrorOp Sender is ok
    Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
      Watson (finnish streaming app) perfect
      Svtplay black screen with sound, think it has something to do with bottom status bar.
      Originally posted by jlunse View Post
      To fix the problem with no picture on SVT Play, try with Settings --> Developer Options and enable: Force 4x MSAA
      Thankyou. SVTplay problem solved.
      Netflix (nordic) shows api 19, not perfectly smooth and not the best bitrate but much better than on Minix x8h. No 5.1 sound, subtitles alright.
