Power on/off/standby
Originally posted by thedude2014 View PostI should have been more specific. I realize that an app can bring up a menu to power off the box, but I would like to know if the standard remote(or any remote) can be used to power off the device by simply pressing a button on the remote. Maybe, a shortcut could be created and button mapped?
If the box is dead cool, the power consumption cannot be higher than 0,5W or so, but never measured it.
There’s no other reason to turn off this box, or there is?
120" screen, EPSON 6100W, YAMAHA RX-V775, B&W 603 (front), B&W CC3 (center), B&W DS3 (surround), Boston Acoustics SoundWare XS (front heights), SVS SB-2000 (subwoofer)
M8 TV Box Codesnake's OpenElec 6.0.3
Tronsmart MXIII+ (v108L1) + KODI 16.1 (Jarvis)
Originally posted by thedude2014 View PostThank you for clarifying. I will take a closer look at this. From a glance, it appeared it was staying on due to the (blue) light that remains lit.
There is older threads that i cannot locate at minute...
#80
But the Box has Issues and will not switch off as in no power to box
Some are using this
http://www.****.com/itm/US-Plug-Wire...item5d4a030a9b
Just an example that I found quicklyLast edited by trebor; 06 September 2014, 20:22.
My blue light turns off as it should but there is no red light some talk about. I repeat, mine is not original as defined in this forum.
Enviado do meu ME302C através de Tapatalk120" screen, EPSON 6100W, YAMAHA RX-V775, B&W 603 (front), B&W CC3 (center), B&W DS3 (surround), Boston Acoustics SoundWare XS (front heights), SVS SB-2000 (subwoofer)
Originally posted by TMx View PostThere is No RED Led in this boxes Blue Led only....
maybe this thread I started and took snap shots will explain it furthur
JustMeBugs are Sons of Glitches!
JustMe
[QUOTE=thedude2014;224711]@JustMe Nice idea...I will be trying those methods. Light is just too bright! Would be great if an update would include the light turning off during sleep mode...if possible. [/QUOT
now your asking for million dollar lottery, not only do you want the cake but you want the cream too
JustMe
There are currently 1854 users online. 1 members and 1853 guests.
