MK809III Netxeon Help needed
    Hello.
    My friend tried to update his TV Stick MK809III PCB Netxeon Box v1.0 20140122.
    Unfortunately, this stick is not so easy to update like mine and so he lost his original rom. No backup.
    Have somebody this rom? Or an idea which rom would work without bootloop or other trouble like no working USB, Wlan etc?
    Best regards
    Erwin
    Originally posted by Niwre View Post
    Hello.
    Best regards
    Erwin
    Yes, here you go --> http://www.freaktab.com/showthread.p...4-4-2-*Update*
    Neomode
      Originally posted by neomode View Post
      Thanks a lot, Neomode
      The stick is alive again.
      Old Version:
      http://www.freak-tab.de/neomode/NCR_3_MK809III_44.zip is working.
      Desk wallpaper blinks!?
      Wlan OK but a bit unstable. A well known problem
      Ethernet not work.
      Host USB dead? Only the mini USB works.
      Have to check all functions ...
      Will report later ... Thank you
        Okay ... Ethernet works. Wallpaper blink no more.
        Will wait so kernel give chance to set.
        Best regards
        Erwin
          So far, so good. In principle, everything works as desired. Only videos with 1080p stutter horribly. Videos with 720p run smoothly.
          Wlan Tethering works fine for Yatse.
          Host-USB works.
          Mini USB works.
          Ethernet works.
          Other features seem also work.
          Desktop still blink. Why?
          Best regards
          Erwin
            Try the KitKat Kernels from D33 for AP6210 TV Sticks.
            Then it should work better. The Problem itself is there are tho many Clones of the MK809III this make it to me very Hard to make a Custom Rom.
            Neomode
              Hallo
              ich habe den Stich auch und bin auch schon am suchen!!!!!
              dachte nicht das das so ein unterfangen ist mit eimen Clon.
              Werde das rom gleich mal probieren..... welchen Kernel hast du ausprobiert...
                Hallo
                Läuft auch nicht, gibt es ein rom auser das orginale
                  Nimm mal mein Rom for den MK802IV New Wifi vielleicht geht der. Nächste Frage wie wird der Stick mit Strom versorgt?
                  Gesendet von meinem HUAWEI P7-L10
                    Danke für die schnelle Antwort
                    Ich habe das orginal Netzteil welches 5V und 2000mA hat.
                    qqdqd
                    Habe ein rom gefunden läuft bis dato ganz gut
                      Hi Neomode Thanks for your help and patience. I'll stay with the English language so that others people around the world can find also a solution for their problem
                      Now to the topic. I need a target instruction, because although I can cope well with Linux, but these TV sticks are still relatively new territory for me.
                      Where exactly can I find this kernel?
                      To flash the kernel I need only remove all hooks of the other modules in the flash tool and flash only the new kernel?
                      Thank you
                      Erwin
                        I'm there all the tested kernel and had no success have now been playing this rom
                          Um ... I think that I found it there
                          Now I had flashed your 4.4.2 but D33's kernels are for 4.2.x
                          Have I flash only the kernel from D33 and the right bootloader?
                          Or have I to do more?
                            Okay ... Had made a complete dog's dinner of it and bricked this minx. Reanimated by shorting pin 8 and 9 of the NAND chip while powering on.
                            Then flashed Finless ROM 2.0 - KitKat 4.4.2 for AP6210 wifi - BETA with Finless Kitkat 1080 kernel. Same result. Horrible stuttering with HD movies.
                            Slowly I really begin to hate this stick.
                            Oh ... often was asked for the power supply. In my case it is a 5V/2A. My own TV stick (different item), incidentally, works perfectly with this power supply and without stutter in SD and HD.
                            But this stick is a real bitch.
                              It is the rom. Take the Rom for the MK802IV. This can be work.
                              Neomode
