Touch Screen
    Touch Screen
    Hey friends. I was thinking of using this or another rk3 28th box for a carpic project. My question is will a chalk electric or any other hdmi/USB powered touch screen (7 inch) work or will I have to make changes? Any help would be appreciated.
    USB-GPS and Chalk Touchscreen work with Kernelmodules on my minix x8-h.
      im not sure i understand. can you elaborate
        I have made a tutorial in the Minix Forum. Search Chalk or GPS in the Forum.
          I think "USB HID" is the keyword? Right?
          RK3288 Devices
          - Overview BOX (LINK !)
            Hi Wal,
            Is that module you compiled only work for Minix-X8? When I try to load module on to S89, I got error like below.
            "insmod: init_module '/system/lib/modules/hid-multitouch.ko' failed (Device or resource busy)"
            Do I need recompile with S89 kernel configuration?
            MG.
              Originally posted by woomg View Post
              Hi Wal,
              MG.
              That error is exactly that. Either it is not compatible with the kernel or it is already built in the kernel.
              DMESG usually gives you more details of that error.
                Thanks Bob,
                I did not check DMESG....
                It's already registered modules on S89 kernel(FINLESS 2.0 firmware). That touch driver is modified version.
                So I will check again with LEOLAS firmware(he tried diet the kernel....^^;, and if I have same issue, I need to make whole kernel replacement kit...
                Thanks again....
