Pandigital Planet, and GO Launcher EX not playing together nicely
I haven't found any references to the Pandigital Novel or Planet here. Anyone know anything about them? I have a weird problem with a PDP that I really don't want to replace. GoLauncherEX is failing on homescreen launch, leaving me with a blank content screen, with a working notification banner. I need to figure out how to return to the factory launcher so I can uninstall GoLauncherEX. Help, anyone?Tags: None
Originally posted by Fenshaw View PostI haven't found any references to the Pandigital Novel or Planet here. Anyone know anything about them? I have a weird problem with a PDP that I really don't want to replace. GoLauncherEX is failing on homescreen launch, leaving me with a blank content screen, with a working notification banner. I need to figure out how to return to the factory launcher so I can uninstall GoLauncherEX. Help, anyone?
You should be able to modify the launcher from the go launcher app, which controls the launcher. If not, find where you uninstall apps and uninstall it.Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
I plugged mine in to charge it up, because it was dead from being unused for so long.
When I do, there is the back button, home button and a menu button. If you press the menu button, it brings up a menu at the bottom. From there, go to settings, then Applications, the Manage applications, then find GoLauncher and tap, then go to uninstall.Currently Inactive on Freaktab.com
Thanks BudgetGeek
I appreciate you taking the time to answer. Actually, the Planet is a darned handy item. Comes with the market, and runs most apps. I was overthinking the problem, and found the solution in a pile of old musty tools for the Novel. I installed a prehistoric copy of PandaHome, launched that on boot-up, and was able to uninstall and reinstall GoLauncherEX. Took me four days, but stupidity and dogged determination won out in the end. Thanks again.
There are currently 1016 users online. 0 members and 1016 guests.
