beelink MXIII, windows 8.1
Here is the stock firmware (factory firmware) for the following products: http://www.geekbuying.com/Search/?keyword=MXIII There are two version for this tv box. 1GB RAM version with realtek rtl8188 chip and 2GB RAM version with broadcom AP6330 chip. Because there are two ways to update firmware for amlogic device, read here. So i offer two different firmware for […]
=> http://blog.geekbuying.com/index.php.../#.U4PlHyg5WCA
RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View Post
For tronsmart
Not for MXIII
I know is most of the same hardware
Come on, if ALL roms for round s802 devices, and tronsmart s802 is also a round one, works at MXIII(2GB), what do you think will happen with the driver and flash tools for the round ones? (btw: have a look at my post count and maybe then you will be able to trust my helping hand...)
Anyway, the driver and flash tool are for s802 so it will also work at MXIII(1GB)...RK3288 Devices
Originally posted by no_spam_for_me View PostCome on, if ALL roms for round s802 devices, and tronsmart s802 is also a round one, works at MXIII(2GB), what do you think will happen with the driver and flash tools for the round ones? (btw: have a look at my post count and maybe then you will be able to trust my helping hand...)
I know
Thank you
Only to be save, I only talk about the "USB Burning Tool" (which you don't need at the custom roms because they use a normal SD card to flash via recovery) and NOT about the "BOOT SD Card" because this special SD card use some parts that maybe will brick your device!RK3288 Devices
Originally posted by no_spam_for_me View PostOnly to be save, I only talk about the "USB Burning Tool" (which you don't need at the custom roms because they use a normal SD card to flash via recovery) and NOT about the "BOOT SD Card" because this special SD card use some parts that maybe will brick your device!
I dont have a micro sd card, anyway
Originally posted by mattyspurs76 View PostBeen a few weeks since i updated my firmware but tbh your better off checking out a custom job such as wassers or finless.
They both use the latest firmware and seem better than the stock firmware.
Bith are easy to install but you do need an sd card and pc to transfer the files to.
I can not just use usb buring tool ?
Originally posted by hup View PostI can not just use usb buring tool ?
Order a cheap microSD at ****...
EDIT:
Forget, but you can also use every fat32 USB device instead of a SD card....RK3288 Devices
Originally posted by no_spam_for_me View PostNO, 'USB Burning Tool' need a special format (.IMG) with all in one...
EDIT:
Okay
I have a old 4 GB usb device
Of is better, i buy a cheap sd card?
There are currently 3315 users online. 6 members and 3309 guests.
