NEW CR11S/CS968-CS968 htc t018 MTK OVERCLOCK 1704 1080p 4.4KK ROOTED {Clean You Customized} 2/5MP Ap6210, AC3/DTS
    The NEW Just Released CR11S/CS968 And CS968 htc t018 MTK Vanilla Ice, OVERCLOCK 1704, ROOTED 2/5MP 4.4 kitkat ROM Build based on the newly released htc t018 MTK 8/12/2014 version with built IN AC3 DTS, enhanced video resolution quality ...
    *PLEASE NOTE: THE CS968 htc t018 MTK 1080p AC3/DTS VERSION {WiFi AND Bluetooth Doesn't Work, A WIRED CONNECTION WORKS ONLY}
    You can customize this ROM build to your exact taste ... Just about ALL the Multi-Media Super ROM apps you see in the photo below can be download by following the link below ...
    You can get the new latest Multi-Media Super ROM App Package like in the above photo by following the link below ..
    *DOWNLOADS ARE READY NOW ...!
    DOWNLOADS:
    *{All DOWNLOADS From Now On Will Be In The Top Pinned Post {MIDDLE SECTION}, NO MORE SCROLLING ...
    *Get the NEW Android TV CR11S/CS968 And CS968 htc t018 MTK 1080p Vanilla Ice Clean ROM Build And Multi Media Super ROM Apps Package
    HERE
    https://plus.google.com/communities/...artnerid=gplp0 ...
    These ROM Builds Are Rock Solid, No Constant Rebooting
    I want you guys to know these Cloudnetgo CR11S/CS968 1080p 4.4KK ROM builds are based on the latest 7/10/2014 released ROM Builds ...
    These CR11S/CS968 ROM builds boots up in lest than 5 seconds, just like the original Cloudnetgo stock 4.4KK ROM build does {FAST BOOTING TECHNOLOGY BUILT IN} ...
    Also their is no constant reboots out of the blue, these ROM builds are rock solid, no overclocking, and will not run your Android TV box hot ...
    *As you know already, when you install this CR11S/CS968 1080p ROM Builds on the htc t018 MTK CS968, the WiFi and Bluetooth will not work at this time ...
    You will only be able to use a WIRED Ethernet Internet connection, everything else seems to be working perfect on a htc t018 MTK Android TV box, even 1080p movies via MXPlayer/BubbleUPnP with a License ... Also 1080p movies works very well via a Plex server set up on your home network ...
    Remember these ROM builds are clean to the bones, therefore you must customized these ROM builds to your exact taste, no Gotham XBMCs are pre-installed ...
      Can we have Both WIFI/BLUETOOTH and 1080p on HTC MTC ROM
      Hi Tech, i have a question ,
      Is it possible to have both WIFI/Bluetooth and 1080p on the same HTC MTK ROM.
      I will love to have both please.
        Yes, it's possible, but I don't have a htc t018 MTK 1080p kernel with WiFi and Bluetooth working at this time, maybe later ... I just sent you a PM to you ...!
          Lots of us would like that!
            If you could combine this ROM with the D33 kernel http://www.freak-tab.de/d33/kernel_KK_v4.2.5_MT5931.zip you will be the one. Camera will not work, but Wifi and BlueTooth will.
            Great work man, we are almost there.
            Also, I really like to have this
            1920x1080-60
            1920x1080-30
            Nothing more I neeed.
              Vanilla rom on AP6210 CR11S 5mp review
              Ok, I loaded the rom on my CR11S version 1 device and here are my findings:
              1) It's very clean, nothing on it like advertise so you can customize at will.
              2) Performance on Antubu hits 22,054 (my old one is 21,789), however, it's not smooth at all, jerky when moving through home screen or open/close app draw. I reduced the animation from 1x down to .5 then 0, but no help. Now I haven't install anything except for Antubu and let it settle for 2 hrs before the test.
              3) 3 newly downloaded apps FC without messages, just closed and need to reopen again.
              So just for item 3, I stopped testing and flash back to the old rom and right away I, again enjoy the super quality and smoothness of the rom. Booting up took around 30 sec. I will pass on this one. Remember people the rom may not work well on my device but maybe do well on yours, so give it a try. Good luck.
                It's very strange I'm not experiencing anything close to what you described above, game knows game ... Another thing to after the Google questions, it takes lest than 5 seconds for this ROM to boot up instantly ...{lol}
                  HDHomeRun Prime Box
                  I'm now testing a HDHomeRun Prime box, it will be required for the coming Google Android TV "L" devices to access live TV/TV Guide ...
                  IN THE ABOVE PHOTO I'M WATCHING LIVE HD CABLE TV, VIA THE HDHOMERUN PRIME BOX, VIA ANDROID TV QUAD CORE BOX {Works As Advertised} ...
                    HDHomeRun Streaming Devices Adds Another Dimension To *Android TV
                    HDHomeRun Streaming Devices Adds Another Dimension To *Android TV ... I Can See Already How This Will Enhance Google Android TV "L" Devices With Live TV And TV Guide ....
                      No App {FORECLOSURES} Were Found During The Multi ROM Build Test
                      I Retested ALL My New Latest ROM Builds For App Installation And To See If Any App Would Give A {FORECLOSURE} ... As You Can See By The Above Photo, I have Just About ALL My Multi-Media Super ROM Apps On My Android TV Quad Core 4.4 Box, Not Even ONE APP {FORECLOSED} During The Test ... Believe Me, When It Comes To These TV Boxes, I know My Game And Game Knows Game ...!
                      A Tip And A Trick, If You Should Encounter A APP Foreclosure, Go To CloudnetGO Website And Install A 100% Pure Stock ROM For Your Android TV Box, This Will Restore The Correct Properties And ROM Components To Your Android TV Box, This Will Also Help With Boot Up Problems Too ...
                        NEW XBMC {Kodi 14.0 Alpha 3} Playing Live TV In 1080p Dolby Digital Plus 5.1
                        NEW XBMC {Kodi 14.0 Alpha 4} Playing Live TV In 1080p Dolby Digital Plus 5.1 Via HDHomeRun Prime Via Android TV Quad Core 4.4 Box ....
                        Get the NEW XBMC {Kodi 14.0} HERE http://xbmc.org/download/#alphabuilds ...
                          NEW Ultra HiDef ROM Build
                          NEW XBMC {Kodi} Is A Dream Machine For {Live TV} Via Android TV
                          Quad Core Boxes
                          Here is the private ROM Build that I Use ... It's a CR11S/CS968 AP6210 Ultra HiDef 1080p/4K ROM Build ...
                          You will need the No-Frills CPU Control app, I'm advising you to run this ROM at 1416 GHz ...
                          DOWNLOADS:
                          *Get the NEW Android TV CR11S/CS968 And CS968 Ulta HiDef 1080p/4K Clean ROM Build And Multi Media Super ROM Apps Package
                          HERE https://plus.google.com/communities/...artnerid=gplp0 ...
                            Picture In Picture, HDMI IN/OUT 3288 SoC
                            A Android TV 4.4 Quad Core Box With Monster Specs, Featuring {PICTURE IN PICTURE PIP} 1080p/4K, HDMI IN/OUT, 3288 SoC ... Features You Will Not Find On The Coming Goolge Android TV "L" Boxes/Game Consoles
                            You Can Get More Details HERE
                            http://www.cnx-software.com/2014/08/...t-and-hdmi-in/ ...
                            IN THE ABOVE PHOTO IS THE UPSCALE NEW {"POPCORN TIMES"} LATEST MOVIES APP WORKS WITH ALL ANDROID TV 4.2/4.4 QUAD CORE BOXES, *ChromeCast, *VPN Supported, *VPN MUST ACTIVATE IN THE SETTINGS AREA {Follow The Download Link Below}
                            IN THE ABOVE PHOTO IS THE NEW UPSCALE Latest {Preminum MOBDRO} App WORKS WITH ALL ANDROID TV 4.2/4.4 QUAD CORE BOXES {Follow The DOWNLOAD Link BELOW}
                            {BACK BY POPULAR BY POPULAR DEMAND ...! NEW {ALBAPP TV.APK} Multilingual, OVER 150 CHANNELS OF GLOBAL SPORTS AND TELEVISION ENTERTAINMENT {Most Channels Are In Awesome Video Resolution Quality}
                            IN THE ABOVE PHOTO IS ONE OF THE HOTTESET ANDROID TV APP, THAT CANNOT BE FOUND IN THE GOOGLE ANDROID PLAY STORE MARKET ... The SUPER
                            Torrent Stream Controller App Give You More Then enough {Movies, Sports, Total TV Entertainment At Your Fingertips} WORKS WITH ALL ANDROID TV 4.2/4.4 QUAD CORE BOXES {Follow The DOWNLOAD Link BELOW}
                            *Please Note: The SUPER "Torrent Stream Controller App" For Best Video Resolution Quality, You Will Be Asked To Download {Auto} The "Ace Stream Engine App" ... Also Install/Download the Free "Archos Video App" {From Google Play Store} And You Will Want To Add The "Archos MPEG2 Plugin App" {From The Play Store} ... {USE THE ARCHOS VIDEO PLAYER FOR ALL VIDEO PLAYBACK}, This is a SUPER Android TV App ...!
                            DOWNLOADS LINKS
                            The Above Apps Can Be Downloaded From HERE https://plus.google.com/communities/...artnerid=gplp0 ... The Above Apps Downloads Are Located In The Top Pinned Post, Just Click On "Read More" To Expand The Post, The Downloads Are Located At The Very Bottom Of The Post, enjoy a must have on your Android TV 4.2/4.4 Quad Core Box ...!
                              Android TV Entertainment Plus Multilingual Movies, Sports And News
                              Just to let you guys know in the above post {SEE PHOTOS} are three mega super apps, That will give you ten times more Android TV entertainment, than your XBMC FREE ... Movies, Sports and worldwide news feeds, these apps have been around for a long time, but they have been just upscale updated with new added features, plus they are multilingual, enjoy ...
