UBOX R89 and Beelink R89
    hello i see on the bee-link site the;UBOX R89 and Beelink R89, the specs looks exact the same, did a research but couldn't find any difference. anyone knows what the difference is between: UBOX R89 and Beelink R89? i can order now the ubox r89 16gb (beelink r89 not yet available to order), but i have now the beelink m8 round box and kinda satisfied about beelink and about the support of @oman here.
    please tell me what the difference is as i want to order as soon as possible due the delivery time and any day longer is a torture for me
    Both are made by Netxeon.
    Beelink is Netxeons own brandname but they also make devices for other companies, example UBOX. I think they are the same but there might be minor differences in components used.
      Originally posted by ssspacman View Post
      Both are made by Nexteon.
      Beelink is Nexteons own brandname but they also make devices for other company, example UBOX.
      Maybe I'm wrong, but I bet UBOX is also a Nexteon brand, because all 8GB test-devices are UBOX...
      RK3288 Devices
      - Overview BOX (LINK !)
        Re: UBOX R89 and Beelink R89
        thanks guys so the quality should be the same i guess?
          yes, all parts (case, pcba...) the same, only other print at the case...
          RK3288 Devices
            thanks, just ordered the ubox r89, can't wait to play with it. as far as i can see the only difference between 8gb and 16gb is the wifi chip, the 16gb has dual band and wireless ac ( AP6335)
