MK808b Windows found and installed drivers!
I put my MK808b in flash mode via the reset button method (in order to flash Finless 1.7), but I can't install the custom drivers because my computer (Win 7) recognized the device and claims the drivers are up to date. How do I override those to install the custom drivers???Tags: None
If it isn't truly in flash mode, Windows might pick it up as a storage device and won't prompt about drivers. Make sure that the recovery button is being held down (you will feel a click) and do not let go until a few moments after you connect it to your PC.
Start button -> Right-click "Computer" (or My Computer / This PC) -> Manage --- Under System Tools click Device Manager --- see if mk808b/rockchip is in the list (maybe under universal serial bus controllers). It might be shown as unknown device, that means you need to right-click it and select install driver.
There are currently 1248 users online. 1 members and 1247 guests.
