can some one explain how to set permission /dev/am* M8 box
    i have set permission via terminal emulator chmod 777 /dev/am* , and then after reboot permission gone ,how can i set permission permanent in m8 box
    I take it you type:
    su
    chmod 777 /dev/am
    Why do you want 777 anyway? That file wants 666 (rw-rw-rw)
    Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
    Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
      Originally posted by ant View Post
      I take it you type:
      su
      chmod 777 /dev/am
      i have set chmod 666 /dev/am* for android terminal. xbmc video working fine and then after reboot M8. The default mode looks like that rw-------.how can i set permanent permission rw-rw-rw
        I only have minix x8 as a reference but they handle a lot at init.rc and init.amlogic.rc (and maybe more)...
        So you must use something like 'Android.Image.Kitchen.v1.8' to strip the boot.img, edit the files and rebuild the boot.img (and also build a correct update.zip)...
        If the rom you use allow to handle init.d (ore something like this) use it with a script...
        RK3288 Devices
        - Overview BOX (LINK !)
          Having the same problems as above running Finless 1.8 and XBMC downloaded from the website.
          Is there any way to automate setting the permissions? or even have a script I can run from a script manager?
            My init.d permission scripts if you want to try?
            Just download > unzip > read README > move files > reboot
            Init.d permission script for XBMC
              Cheers - Ill give it a try and let you know how I get on
                If the box/rom/fw doesn't support init.d
                RK3288 Devices
                  Just tried this and it appears to be working!
                  Thanks for sharing it
                    That's ok dude! Nice to hear it's got you up and running.
