IR Remote keymapping
    I use an Ugoos UM2 with a Neomode firmware. This firmware (tried also some other firmwares, must none had a correct mapping except the stock firmware) has an incorrect keymapping of my IR remote, which makes it difficult to use it. So I want to fix this....
    But how? I assume these mappings are stored in the kernel? Can I alter these?
    Or maybe a keymapping in XBMC is enough?
    Maybe FLIRC?
    FLHT = Harley
    HEMI = 2010 Dodge Challenger SRT
    Cause I've been asked.
      Originally posted by flhthemi View Post
      Maybe FLIRC?
      http://flirc.tv/
      THe problem is the IR is already installed (and configured) but don't know where and how. This tool works if no IR driver has been insstalled.
        ok
        See this
