Best firmware for my M8
    Hello. This is my first post here and I'd like to say a quick hello.
    I have a question. What is the best firmware for my new 2GB/8GB M8, I take it that stock rom isn't the best so I'm looking for recommendations for alternatives and the reasons why.
    I got my M8 from here http://www.geekbuying.com/item/CM8-A...ck-332036.html
    I use stock. No problems so far. With other firmwares I had some ramdom reboots or bad performance in gaming.
      all depends on preference really , 1.7 finny, LF, stane, stane linux choose your flavour and test it doesn't cost anything and post your own individual results
      JustMe
      Bugs are Sons of Glitches!
      JustMe
        I'm just worried about bricking my box with the wrong ROM. Money is tight and I can't afford to replace it.
          Before you begin to play with different FW have a look at the sub-forum for the square boxes and check if it is a clone or not !
          RK3288 Devices
          - Overview BOX (LINK !)
            Thanks for that. I'll open it up and compare. Hope I've got a real one.
              I would also like to compare a few other firmwares but would like to return to my original shipped firmware if I needed to do so.
              How can I create a back up image and restore if needed ?
                With TWRP. I linked you to it yesterday....
                or
                Go to manufactures website and find the stock firmware.
                You can find firmware build detail in settings/about device
                Minix Neo X7 - Wasser 1.0.4 OC'd - Kodi-helix with passthrough
                Beelink M8B - Wasser 1.0.3 - Kodi-helix alpha 2 + SPMC
                  I just started a thread (should've looked here first doh,) I gave finless 1.7 a try but like u random reboots, but now I can't can't get back to the stock? How did you do it and which version firmware did you use?
                    I use this one.
                    I just installed from recovery with toothpick method
                      I use this one.
                      Thx Skelton
                      Do u have any issues with XBMC on this firmware? I had interlace (like pixelation) issues with the newest firmware
