HELP!!!!!
If this not help, had you already checked what I had wrote at post #4 ?RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostYes, the one at the A/V hole you need to flash one of finless zip's...
Originally posted by JustMe View Postif it the whole box issue
go to settings --> Display --> Display Position ---> set to around 92%
also set your resolution 720p or 1080p or 1080i
if it in xbmc the issue then
go to --> system --> video ouput --> video calibration
JustMe
Originally posted by no_spam_for_me View PostIf this not help, had you already checked what I had wrote at post #4 ?
I have downloaded both APK's and put them on the SD Card but they do no show up in the update screen?
I did try to install both but it says that XBMC is already on my device. I will uninstall and try againLast edited by riddick187; 11 September 2014, 17:25.
No update screenit isn't an update, it's an app
You need to open it with ES ore something like this...RK3288 Devices
There are currently 2105 users online. 0 members and 2105 guests.
