FULL REVIEW WITH VIDEOS of the MXiii 4k android TV Box from Gearbest
    Introduction & What's in the Box
    There are literally hundreds of android tv boxes out there, that's why i always try to present you with the best of the best.
    This time Gearbest were kind enough to send me an MXiii 4k Android TV Box sample for review.
    The packaging was very professional and it provided some basic info about the hardware ports
    Opening the package we can find that it includes:
    • The MXiii itself
    • An ir remote controller
    • An AC adapter
    • An HDMI cable
    • An A/V cable
    • A User Manual
    • A USB OTG Cable
    Specifications
    This device is a powerhouse and under the hood it packs some very impressive specs.
    Starting with the hardware, the MXiii is powered by the latest Quad Core AmlogicS802 running at 2.0 Ghz. An Octa Core Mali-450 MP8 GPU handles the graphics and you will never run out of rammemory because it packs 2 gb. The internal nand flash is 8 gb and it's enough to install apps although the box has a card slot to expand your storage up to 32 gb
    Connectivity
    The MXiii lacks an external wifi antenna but it doesn't matter because the reception is absolutely great and stable.
    As far as connectivity goes Bluetooth 4.0 is supported as well as WiFi 802.11 a/b/g/n/ac which has a great reception and is very stable.
    This is from my home network. Between my router and the Box there are 2 concrete walls
    Plenty of ports are also available which include:
    • 2 full USB 2.0
    • SPDIF Optical Audio Output
    • Ethernet Port
    • DC Input
    • HDMI Output
    • A/V Output
    • MicroSD Card Slot
    Externally the MXii has a nice matte finish on top with a nice shinny logo printed on it
    On the bottom sidewe see the ventilation holes and on the sides the different ports the device has
    Software
    Looking at the software we have 2 launchers. The mediabox launcher and the stock one
    The first one has aWindows 8-like tile based ui while the second one has the normal android interface
    Going to the mediabox settings we can see 4 tabs
    The first tab is the Network Tab and it shows the available Wireless Networks. You can also setup your ethernet connection here
    The second tab is the Disply Tab where you can adjust your display scale, position, and setup your HDMI connectivity
    The third tab is the Advanced Tab. Here you can setup your Miracast function as well as the Audio Output and HDMI CEC Controller
    And the fourth tab is the Other Tab where you can find your system information and updates as well as enter the stock android settings
    Performance
    Performance-wise the MXiii is very powerfull. The 2.0 Ghz Quad Core Amlogic CPU in addition with the Octa Core Mali-450MP8 GPU give you great performance and you can see that from the scores of some benchmarks i ran on the machine.
    3D Mark
    Video playback is excellent too and you can take a peak at the results of the Antutu Video Tester to see how the device performed on various video formats and resolutions
    Gaming is also possible as the MXiii has a native support for various gamepads. In our occasion i connected an original playstation 2 dual shock 2 controller via a usb adapter and played Riptide GP2. The game ran great
    Video Unboxing And Review In English And Greek Languages
    You can watch my video unboxing and review of the product by visiting the links below
    Unboxing (Greek): https://www.youtube.com/watch?v=s7es...YEl2sXura8yIow
    Unboxing (English): https://www.youtube.com/watch?v=FnDT...YEl2sXura8yIow
    Review: (Greek): https://www.youtube.com/watch?v=Nrjm...YEl2sXura8yIow
    Review (English): https://www.youtube.com/watch?v=4b0v...YEl2sXura8yIow
    Overall Impressions
    The MXiii 4k android tv box is an amazing device giving you the power to transform your living room into a 4k home theater. It has the XBMC preinstalled and it had no problems handling even the most demanding videos. I highly recommend it to everyone due to it's raw power and it's aggressive pricing.
    Pros:
    • Power and Performance
    • No heat Issues
    • Great WiFi and Bluetooth reception
    • Price
    • Build Quality
    • Portability
    Cons:
    • Only 2 USB 2.0 Ports
    For orders visit:
    www.gearbest.com
    www.gearbest.com/tv-box/pp_67822.html
    And to buy it cheaper at 78.98$ or approximately 61 Euro
    use this COUPON CODE: GBM82LG
    Thank you and as always, for more unboxings, reviews ,news and tutorials follow me and subscribe
    And the best: you can use every round devices fw at the 2GB MXIII...
    Originally posted by oman View Post
    FW is the same with s82(The round one)...But only the 2G DDR with WIFI/BT one..There is another version is 1G DDR with WIFI only..
    If you have the 2G version,then there's so many FWs for you.
    Some other useful links
    RK3288 Devices
    - Overview BOX (LINK !)
