Help me pick the right custom ROM
    Ok i want to put a custom ROM on my device because the stock one sucks but i am not sure which one is compatible with my device, the model of this device is supposedly CS918 according to the vendor, but i am not certain, they arent very helpful. I cant get in my case to see motherboard chip because i dont have correct screwdrivers (tiny tiny heads) and not keen on buying some.
    These ar ethe pics of my device below that i hope are enough for someone to advise me, i want the new ROM to run much smoother than this horrible stock rom that is crashing alot and really annoying.
    Hope someone can help..thx alot
    Without a dmesg no one can help you.
    Also you are running a Jellybean ROM, so the manufacturer probably also don't have a KitKat ROM and never will.
    You might be able to try a KitKat Rom if another ROM is compatible with your wifi chip.
