Cheers.
Recommend a usb to ethernet adapter
Guest
Originally posted by smith4130 View PostCan someone recommended a usb to ethernet adapter that will work with rkm3188iv old wifi.
Cheers.
If you do a search on this forum for USB ethernet, you will find recommendations for an ethernet device.
You can also do a google search for ethernet USB for android and several suggestion on the market will come up.
I suggest not to get a gigabit ethernet usb device as the drivers are not ready in the kernel and will not work unless you can compile and install them and activate it in android.
There are currently 2345 users online. 2 members and 2343 guests.
