Issues with new 3188-T box.
    Hi! I am new to freaktab so if I am posting in the wrong area, do appologize. I have a box called Biidi T2, bought in China. It is a RK3188-T box with bluetooth and wifi ofcourse. I have two issues with this box. It doesnt have any microUSB so I can't connect it to my PC. It has only two full sized USB connectors. In the settings I can toggle a setting called "Connect to PC". Is there an easy way of connecting the box to a PC at all?
    The second issue is to hopefully find an alternative firmware for my box. I have tried different XBMC apk that should be optimized with this cpu but I still have problems with smooth playback. I will attach two pictures. Hopefully someone can identify it.
    Thanks in advance.
ID:	439511Click image for larger version
Name:	Biidi T2 3188-T.jpg
    Thanks in advance.
    [ATTACH=CONFIG]7918[/ATTACH][ATTACH=CONFIG]7917[/ATTACH]
    Try to get rid of the box as soon as possible.
    You won't have any support or get firmware updates.
    Get a similar price Amlogic Quad-Core Box.
