firefly .IMG can be used to boot linux on any rk3288
Originally posted by scandog View PostRK3288 Devices
- Overview BOX (LINK !)
I'm bee link 16gb
Originally posted by no_spam_for_me View PostI haven't looked at it (actually downloading) but if it writes all at the nand (instead of using external device for the Linux-FS partition) then it could be that the ones with problems uses a 8GB device...???The funniest thing about this particular signature of mine is that by the time you realize it doesn't say anything it's to late to stop reading it
NO way at 8GB devices
If I have a look at the parameter I find this CMDLINE which seem to be OK
Code:CMDLINE:console=ttyFIQ0 androidboot.hardware=rk30board androidboot.console=ttyFIQ0 board.ap_has_alsa=0 root=/dev/block/mtd/by-name/linuxroot rw rootfstype=ext4 init=/sbin/init initrd=0x62000000,0x00800000
Code:mtdparts=rk29xxnand: / length @ start-address (HEX) => DEC 0x00002000@0x00002000(uboot) => 0x00002000@0x00004000(misc) => 0x00008000@0x00006000(resource) => 0x00008000@0x0000e000(kernel) => 0x00010000@0x00016000(boot) => 0x00010000@0x00026000(recovery) => 0x0001a000@0x00036000(backup) => 0x00040000@0x00050000(cache) => 0x00002000@0x00090000(kpanic) => 0x00180000@0x00092000(system) => 0x00002000@0x00212000(metadata) => 0x00200000@0x00214000(userdata) => 0x00620000@0x00414000(linuxroot)=> 4276224 (+ 6422528 = 10698752) -@0x00a34000(user) => 10698752 / 1024 / 1024 => ~10.2 GB
RK3288 Devices
Originally posted by no_spam_for_me View PostAs I though, it couldn't work at 8GB devices
thanks.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Re: firefly .IMG can be used to boot linux on any rk3288
Originally posted by fossxplorer View PostIs there no way of rescuing yours?
Well, I found out that the ubuntu does indeed kill my R89. I down loaded the Sept. 29 ubuntu and when I tried to install it, I got IDB fault again. GRRRRRRRRR. now back to those dang teeny tinny shorting holes again. One of these days my luck is going to run out...
Edit, now I know how to bring back my R89 to life. It has probably been discussed many times, but since I never ran into this problem, it went right over my head.
To un-brick the box the box, have to get into the "mask" mode, R89 made it easy by installing two teeny, tinny holes to short something that makes it work. I made a jumper by using a piece of old speaker wire, since it was too large in diameter, I cut most of the strands off, leaving a very small amount of strands. Ok, but, the wires just "flared when trying to get them into those teeny, tinny holes. Since I used to be an electrician and did a lot of board work back in the olden days, I knew how to solder and tin the leads. I dug through my junk pile and found one of my ole soldering irons and some solder paste and solder. I tinned the ends of the wire to make the stiff but still very small in diameter.
Even with my failing eyesight, and a trusty magnifying glass I was able to stick the wire I had made into the holes. I then connected the micro usb connector into the R89, depressed the reset button (inside the AV hole) and connected the power. Eurka, flash tool said I was in "mask" mode (whatever that is). Anyway I also found out that all I had to do was click the 'resetDevice" button. Removed the jumper pulled the power plug and when I replaced the plug I was able to flash Finless's rom again.
I think I will wait until some else gets ubuntu running on their RK3288 box.MK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by fernslb View PostGood morning
Do you know if this dual boot works in Ugoos UT-3?
Maybe try this image - http://www.freaktab.com/showthread.p...of-Nagrace-HPH
I will try it out.
What means brick, I think not really brick, but it doesn't work, but if I'm not wrong I think bootloader also works so you can refalsh it via rktool and otg with a working fw (I talk about 'brick' if you also loose this way and have to go via MASK MODE by shorting nand-pins)...RK3288 Devices
Originally posted by no_spam_for_me View PostWhat means brick, I think not really brick, but it doesn't work, but if I'm not wrong I think bootloader also works so you can refalsh it via rktool and otg with a working fw (I talk about 'brick' if you also loose this way and have to go via MASK MODE by shorting nand-pins)...
Well for the fun of it i Flashed this to my ENY RK3288 and a nice surprise it booted up, i only flashed the individual builds no dual boot... its awesome.... clearly some things don't work for my box, ie. WIFI and the IR remote, but hey after all this was for the R89. so what ever. was fun playing.... now back to the crappy ENY firmware
There are currently 3081 users online. 0 members and 3081 guests.
