as first thing i apologize for my bad english . i bought few days ago on myefox.it this tablet and when i see the specs using antutu tester or cpu i got:
cpu arm 7 1.6 clock speed
processor:1
gpu: nothing!
reading the specs i've found that they are very veru different and i have the suspect of have been cheated by the shop but there's one point that's a littler strange: when i turn on the tablet i got the boot reporting n101. in the infos found inside the tablet i got " n101 dual core". the shop screwed me or what? thank you very much
i don't have the gpu info, nothing at all, gpu is not even mentioned! i got one processor 1.6 . The n101 is a dual core ( 800 x 2 ), other? the mali 400 is integrated and this is the reason i don't find it? i tried to installed a game for mali 400 gpu: i can't do that even if i rooted the tablet,
Your right the processor is a Rockchip dual core 3066 and the gpu is integrated into the chipset a quad core graphics chip.
What program are you using to report the hardware?
<input type="image" src="http://www.freaktab.com/attachment.php?attachmentid=565&d=1341333954&thumb =1" border="0" name="submit" alt="PayPal — The safer, easier way to pay online."> https://www.paypalobjects.com/en_GB/i/scr/pixel.gif
</form>
i used several antutu programs like antutu cpu master, antutu benchmarck, antutu tester. so my cpu has a total of 1.6 ghz and not 3.2 ghz as i thought while the gpu is not mentioned in the panel tablet info and that's normal, right?
i have this question: why i am not able to install real racing 2, mali 400 version? doesn'it work on my tablet?
Because a game does not install does not mean it won't work. It is to do with the build.prop and how Google identifies your tablet on the Playstore.
Sent using Tapatalk 2 from Sony Xperia Mini Pro - Ics 4.0.4
</form>
ok and the first part of the post before yours? phonespecs does not have info bout my tablet so i installed android system info, don't have infos for the gpu
