How to determine my WiFi / BT chip?
Try lsub, lspci, dmesg.
You might have to compile some of these tools with the Android toolchain. Alternatively you can grep through the /proc fs
You can also try lsmod or cat /proc/modules and to see what modules are loaded into the kernel. This can tell you if what Wi-Fi drivers are missing which might indicate the chip.
You can also open the device and see what chip is being used.
HTH
There are currently 2386 users online. 2 members and 2384 guests.
