the first thing i change on version 3 is
removed
stock webbrowser
gmail
stock email
google quick search box
sound recorder
sound search
default music player.
i create a cwm zip file for people who want back these apps back in the rom ok.
if you don't want all the apps just open the zip file (don't extract , just open it)
open the map system/app.
remove unwanted apps.
close the zip file.
reboot too cwm and install the zip.
reboot again after install is ok.
now default apps are back installed.
added in rom
adaway
awesome beats audio
replaced apps
google gallery with quickpic.
replaced fonts
ubuntu font now
what i will changes is , default settings after flash
like ....
usb debugging = on
usb connection = mass storage instead off media device
wifi allways on instead off never during sleep
any suggestion or replacement apps are welcome.
offcours with permissions.
don't ask for ETA if i found a good way for default settings i prepare the rom
Verstuurd van mijn ARN10bG3-Freaktab met Tapatalk
