NEW > 3288 EZ Root Tool
    Hi all, I know some 3288 boxes are coming rooted and some are not. Sometimes it's not easy to root a device using some of the other methods out there.
    Well this is super EASY in my opinion and should work on just about any 3288 box.
    This update.zip will:
    Install SU binary and daemon
    Install SuperSU APK
    Instructions:
    DO NOT JUST DOWNLOAD THIS AND PUT THE ZIP ON SDCARD!
    Download this and unzip this package and there will be 2 files
    instructions.txt READ THEM for how to use this!
    update.zip
    Here is the 3288 EZ Root download:
    TOOL -> 3288 EZ Root update ZIP (1.2 megs)
    Enjoy,
    You Rock, man, it will save a lot of time for guys who want to root their device
    Looking for developers
      Thanks Bob.
      The R28 comes rooted using vroot but Bitdefender flagged it as a potential threat, which from previous experience of it introducing malware was a concern, so I let it remove it before trying the update, which works.
        Thanks Bob
        ohh yeah ,it's cool, I'll try it on 2 tvbox, one is a Chinese Band:10Moons D8+, other is HPH V6 4g/32G edition. The stock rom isn't ROOTED.
        Thanks.
          Thankyou Bob.
          Could you make an unroot zip also?
            Enjoy,
            Great stuff. Thanks a lot Bob!
            I opened the archive and packed it again. Now I get "not a valid update package!". How did you sign it?
            Re - a'Bherraidh
              Cheers Bob.
              Just to let you know it worked on a Ugoos UT3 Box.
                Install SuperSU APK
                Instructions:
                update.zip
                Enjoy,
                Update on root method fron Engineer at HPH . 1) open Calculator app , 2) enter !^06^ , 3) device rooted. Have not tried it yet but interesting.
                  Interesting.
                    Tried this method. Works ! Adds Su app.
                      Does it works on any RK3288?
                        l tried it on Ugoos ut3, tronsmart r28 and HPH. All got root.
                          I just tried !^06^ on my UT3 and nothing.
                            It work correctly on my ut3. Finless easy root will work.
                              Just to make sure I'm doing it right. I hit enter after? I mouse click on = after? or do I just type !^06^ and nothing after?
