MXiii | M82 USB to Ethernet 10/100/1000 Adapter
    running the latest firmware, wondering if it is compatible with
    usb 2.0 to gigabit ethernet adapter without needing to install drivers.
    has anyone accomplished this?
    top speed on the modem is 300mbps
    Currently get 24mbps wifi and 32mbps wired
    No one replied. Wth
    anyway I purchased a plugable usb3.0 gigabit ethernet
    does not require driver install. Out the box getting more than double my speed
      sounds great!
      Originally posted by stillhere153 View Post
      No one replied. Wth
      Sounds great!
      What speeds were you getting before using this adaptor and what speeds now you are using it?
      Also, were did you get it? Was it expensive?
      thanks
      James
        Originally posted by jimac View Post
        Sounds great!
        thanks
        James
        floated around 30mbps
        currently getting above 70mbps
        got it off a seller one bay for 16 shipped
          Hey i am also getting slow ethernet speeds! my connection speed is around 13mbps getting only 2mbps on the mxiii
          i bought a usb 2.0 adapter but it won't connect it keeps saying please plug in ethernet cable.
          the usb device itself seems to work because it appears in settings under Ethernet devices.
          i tried to trick it by plugging the ethernet first into its own port then once it said connecting i quickly switched the cable to the usb adapter,
          it worked but the speed was even slower...
          Maybe i am forgetting something?
          please help.
          I am running firmware 114k android 4.4.2 looks exactly like your box mine is 1G ram version.
          the usb adapter is plugged into OTG port
            9 outta 10 this is your problem right here... (IPTV Streams > 10 Mbps = Video/Audio Stuttering).
            Short story... Basically all Amlogic Devices have a MAJOR flaw in the Code that borks the Ethernet on these Devices... A Bug that they themselves had known about since 103k4 (However long ago that was now!). So little chance anytime soon of a fix then. However in the linked Thread above, you can find out how to fix that more or less. That should then get you back to the full 100Mbs again.
            Having done this myself... I can tell you that its like a day to night difference. Having a Wi-Fi ac Repeater set to use ac mode probably helps to... Though the 10/100 Ethernet will always be a the bottleneck in this setup. But, with a corrected sysctrl, you should then get the full speed of your line.
