I'd like to build a kernel for my device.
I wanted to by a CX-919, and got this new MK809III stick mentioned in thread: http://www.freaktab.com/showthread.p...N-with-ESP8089
After some research I've found that there's a build configuration automation (https://github.com/phjanderson/marvin) and a kernel for the chip (https://github.com/linux-rockchip/kernel_rockchip) and there's also a configuration file for the wlan chip in the kernel_rockchip repo. (ESP8089)
Is there a way to build a kernel for this device? If I build a kernel will it work with other ROMs?
I've also found out that the radxa rock rom starts on the stick, but no wlan/bt driver in the kernel. Can I patch it someway?
Regards,
atatek
