aeon nox 5 skin help
hi we are running kodi xbmc with aeon nox 5 skin but we are unsure how to put the shortcuts to the main screen of xbmc like you can with confulence skin , or does aeon nox 5 not support this we have looked around and found some videos on custom but not about adding shortcuts to channels like icefilms etc etc etc , can someone please advise thankyouTags: None
Originally posted by hards View Posthi we are running kodi xbmc with aeon nox 5 skin but we are unsure how to put the shortcuts to the main screen of xbmc like you can with confulence skin , or does aeon nox 5 not support this we have looked around and found some videos on custom but not about adding shortcuts to channels like icefilms etc etc etc , can someone please advise thankyou
UX Team
Originally posted by ultimatexbmc View PostAeon Nox is the most customizable skin there is and it will take you a while to master, there are tons of things on the web to help you with this skin, but you will have to do a fair amount of reading up. You can certainly put shortcuts on the home screen though.
UX Team
http://www.ultimatexbmc.com/
Sorry to say, that off hand I don't remember exactly, but it did take some time to figure that skin out, it has an unlimited ability to be bent to your will, but it will require you to play around with it A LOT, before you can make it do exactly what you want.
Wish I could tell you more but I would be here forever
Team UX
Originally posted by ultimatexbmc View PostSorry to say, that off hand I don't remember exactly, but it did take some time to figure that skin out, it has an unlimited ability to be bent to your will, but it will require you to play around with it A LOT, before you can make it do exactly what you want.
Team UX
http://www.freaktab.com/showthread.p...-ULTIMATE-XBMCthanks
its an old post. Not sure if you figure it out already. Try adding to favorite, aeon nox support adding your favorite to your home screen button
Regards
Simon
Originally posted by hards View Postthanks for your reply but i have looked around and asked so many questions around the net with not a lot of luck , it would be helpfull if you would tellthanks
I have fully customised many skins, up to the point of I want something in between Aeon Nox5 for its big bold blocky appearance all though this skin does NOT allow for customization of adding 'short cuts' as thumb nail icons to every navigation bar item i.e. Video or Programs etc but Rapier skin does, all though as I say its not as blocky of which I prefer like with Aeon Nox 5.
I may look into using Aeon Nox and Rapier and seeing what can to make a skin like this in future but would be a heck of a lot of work but hey, anything is possible.
There are currently 3798 users online. 0 members and 3798 guests.
