Forgive me if this has been asked before though but I can't get XBMC to output audio to 5.1 channels. I'm just using the XBMC Gotham 13.1 build preinstalled by Finless with the ROM
I have all the correct settings:
1. Number of channels 5.1
2. Passthrough enabled.
3. Dolby Digital enabled.
4. DTS enabled.
Is there something I'm missing?
I can get 5.1channels with other builds of XBMC but not with the build preinstalled with the ROM which is a petty because that's the only build which will play 1080p video flawlessly for me.
I have tried to search the forum in case this topic has come up but was not able to find anything. Could someone point me in the right direction?
1080P playback is brilliant. No stuttering or jerkiness. If I can get the audio correct then this would be the perfect ROM/XBMC setup.
