Amlogic S805 is a cost-down cpu of Amlogic S802, it is quad core cortex A5 , not powerful as the Amlogic s802 quad core cortex A9. They remove the 4K support, and make the h.265 support inside.
As far as we know, amlogic is good at XBMC support, so seems Minix want to use this low-cost cpu to get some users which just need good video playback.
Here is the basic information about the NEO X6:
The appearance is almost same as their neo x7 mini, and built in the following port:
RJ-45 Ethenert Jack (10/100Mbps)– don’t support 1000Mbps;
Micro sd card slot
USB 2.0 port
System is also Android 4.4 Kitkat, and RAM change to 1GB, still use the 8GB eMMC.
There is no spdif port, so seems you just can use the HDMI passthrough.
We have got the price for NEO X6, it is $99 with worldwide free shipping, free 16GB 2IN1 U DISK is provided, now you can join our presale for NEO X6 here: http://bit.ly/1DvvAtg
we will start shipping from 30th Sep.
Eric
Geekbuying
Source from: http://blog.geekbuying.com/
