Tronsmart R28 Purple screen problem.
1. Install / flash stock FW
(maybe you don't need it, because I think you are at 108k4)
2. Update FW
a) download file and rename it to update.zip
b) copy the whole update.zip file to micro sd card or usb driver
c) power on your orion r28 and then insert the sd card or usb drive. The system will find a update and ask if you want to do the update, click yes. The orion r28 should do the update and reboot.
If you successfully update, go to setting, check the version, it should be 109k4, and the pink scene problem should be solved.RK3288 Devices
- Overview BOX (LINK !)
There are currently 2737 users online. 4 members and 2733 guests.
