is there any 3288 that can play all?
    Is there any 3288 that can play all?
    i mean:
    1.iso 3d
    2.xbmc clean and fast
    3.new sound format like dts-hd o true -hd
    4.use the iphone as remote for xbmc and games.
    thanks
    i mean:
    1.iso 3d
    thanks
    1. 3D playback is supported, formats depend on the player, etc.
    2. XBMC (and the SPMC fork) works well and is improving everyday. Clean and fast depends on what you're looking to get out of it.
    3. High bandwidth audio such as DTS-HD, etc. is a big question mark.I wish I could test it myself since I run into this question a lot but I don't have the equipment. I'd say stay tuned for that until the capabilities are clarified.
    4. This is possible with android phones and likely is for iphone as well. Hopefully someone reading this can confirm
      soooo
      so the problem are 1,3.
      is there a devide that support the iso 3d and the new sound format?
