Remote control problem
Ok I have 2 m8 square boxes. They stopped displaying any picture but later started working. Yes,I tried different HD leads and tvs. Eventually they just worked. Anyway, the remotes for boxes now don't work but the boxes do. Has anyone had this problem? I've tried different remotes off other m8 boxes and nothing. Batteries are fine. Is this a common problem?Tags: None
Do me a favor. I have many remotes but I did not get one with the M8.
Take a picture of that thing and let me look at it. If I have the remote I may know how to fix it.
Here are the 2 type of remotes
JustMeBugs are Sons of Glitches!
JustMe
The one on the left is what I have. I do not have the one on the right. But it looks like JustMe made a update zip set to switch back and forth so he beat me to it.
Originally posted by stuartj9 View PostIve tried this and re flashing and still remotes do not work with either box. It's strange both have the exact same problem. Can anyone else help?
reflash your box with toothpick also when done go to reset dalvik etc reset box back to factory some time unit get currupt on upgrades, if problem still persits then send box back to supplier.
JMBugs are Sons of Glitches!
JustMe
Originally posted by JustMe View Postreflash your box with toothpick also when done go to reset dalvik etc reset box back to factory some time unit get currupt on upgrades, if problem still persits then send box back to supplier.
JM
Same here, posted about my box dying ages ago and decided it wasn't worth the hassle of getting it replace, so after a month or so of using the CMX box from Geekbuying I decided to open up the M8 and take a look inside.
Everything looked okay so decided to plug it back in and it worked again but remote doesn't work.
I use a RF keyboard anyway so didn't mind too much.
Weird huh?
There are currently 2514 users online. 0 members and 2514 guests.
