S802 Multi Remote Patcher zips
We always appreciate your stuff that works.
Cheers
Originally posted by JustMe View PostUnfortunately I don't have one of those units on hand to test, but at least most of the functions are working good to seem some people appreciate other works
JustMe
Originally posted by jackmate View PostI have got a m8 box ,in which original round remote doesn't respond ,how can I fix this issue ?i get android in screen ,the ir remote doesn't work .should I flash the fw listed in this post ,I can access abdroid recovery but can't navigate anywhere to select update from sd card .
I had to buy new IR receivers and solder them in, which solved the problem, not saying yours is the same issue, but just a thought.
Originally posted by jackmate View PostYes same problem. From where can I buy the ir receiver and how to replace them in box ?
Hopefully that will fix your problem, Not promising anything, but it solved mine.
Let me know how you get on mate.
Originally posted by trebor View PostWe always appreciate your stuff that works.
CheersBugs are Sons of Glitches!
JustMe
Originally posted by gs800uk View PostIm unsure on how to use this updater. Do i copy these files in with the rom package?
download the one you want i assume the m8n remote updator and use the update function programs, andriod apps update/backupBugs are Sons of Glitches!
JustMe
Need some help please.
Hi JustMe,
I got the M8 Box and the remote from the pic, Firmware Finless 1.8 KitKat 4.4.2 ROM for the dated 7/26/2014. The sound, home and menu(3 lines one) buttons have functions mixed between them, all the other functions working good. I wonder witch of the Zip files I need to use to fix? Thanks
I have a little issue now after upgrading to kodi with the remote. I got the regular M8 roundish remote and from what I read this patch is for remotes that stopes working, or mybe i have misunderstood :-)
My Issue is normally I use "Keymap editor" addon in xbmc to remap some of the keys for eksample " I remap the number 1 key to stop" and the number 2 key for pause / resume - In kodi seems like I cant remap the numbers key - and the volume up is now premapped to go to android home page and the vol. down key is mapped to context menu, they now cant be remapped from keymap editor ....
I would love to resume with this simple remote, is there another way to remap the keys by an xml or something like that ???
Thanx in advanced
Originally posted by FrancisBernard View PostHi JustMe,
I got the M8 Box and the remote from the pic, Firmware Finless 1.8 KitKat 4.4.2 ROM for the dated 7/26/2014. The sound, home and menu(3 lines one) buttons have functions mixed between them, all the other functions working good. I wonder witch of the Zip files I need to use to fix? ThanksBugs are Sons of Glitches!
JustMe
There are currently 4190 users online. 1 members and 4189 guests.
