K-R42 Shutdown / Sleep Problem ( Air Mause )
    Hi guys,
    My device is " K-R42 "
    I installed "K-R42 Wasser JB 4.2.2 "
    I'm using the mouse as " Measy Rc11 Gyro Air Mause "
    As problem;
    I can not shutdown and sleep
    I'm pressing the key for the command line that does not happen with the motion is detected..
    when I press the sleep button commands for motion is detected can not
    What can ı do ?
    Help me
    Im sorry but you post is kind of confusing, but I think you are saying: your remote control does not turn off or put your device to sleep.
    Go to this part of the forum and you might be able to find fix for your remote.
