I've an old mk809II with boot loop and i would recover it! This device has a lot of issues. The first, the most important, it hasn't the otg port (is damaged, it is detached...). The second, the device has the pins of the flash attacked at green base and i can't put the thin metal stick between 6th and 7th pin (argh, i tried with needle without success ). I read about 2 iron dots that I should hold, but i don't know exactly which they are, and those that i push seems to do nothing. Any suggestion? Have I chances of recovery my stick?
Mk809II Help for an hard reset
I've an old mk809II with boot loop and i would recover it! This device has a lot of issues. The first, the most important, it hasn't the otg port (is damaged, it is detached...). The second, the device has the pins of the flash attacked at green base and i can't put the thin metal stick between 6th and 7th pin (argh, i tried with needle without success ). I read about 2 iron dots that I should hold, but i don't know exactly which they are, and those that i push seems to do nothing. Any suggestion? Have I chances of recovery my stick?My Devices: Honor 6, Cx-919 (finless 2.0), JXD S7800B (RileyROM 1.2) -
If you're trying to get it into mask rom mode, you don't need to go between the two pins, just touching them with a pin or needle is enough to connect and short them. If you do this and get no result, the next option is to try the other side to see if that works, and then try to short it with another set of pins, 8-9, 9-10 etc and then on both sides.Currently Inactive on Freaktab.com
I use: MK903V | MELE F10 Deluxe | Roku 3600R
RIP: MK808b | MK809III | PIPO M9 Pro
Originally posted by budgetgeek View PostIf you're trying to get it into mask rom mode, you don't need to go between the two pins, just touching them with a pin or needle is enough to connect and short them. If you do this and get no result, the next option is to try the other side to see if that works, and then try to short it with another set of pins, 8-9, 9-10 etc and then on both sides.My Devices: Honor 6, Cx-919 (finless 2.0), JXD S7800B (RileyROM 1.2)
There are currently 2465 users online. 6 members and 2459 guests.
